laser thermometer question
are you guys using..i'm in the market for a better one.. i currently have a relatively cheap one thats acts accordingly..was thinking about the fluke #61, does anyone use that one?
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    the only ....
    thermometer i have ever used has been a Raytek...about a $100.00... works ok...kpc
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Ditto...
    Raytek Raynger with laser pointer. They do have some other real fancy models with memory etc..
    I used to have one like you're looking at. It worked fine although it had a relatively small apperture. Worked great for shooting small diameter tube, but don't do well on large, distant targets.
    ME
  • Glenn Harrison
    Glenn Harrison Member Posts: 405
    I have a Fluke 65
    and it works fine. You can definatly see an accuracy difference between checking dark and light colored objets, but I'm sure that applies to all IR thermometers.
  • flange
    flange Member Posts: 153
    i use the fluke 65 also. just like amex, i never leave home without it. i do a healthy mix of commercial hvac as well as refrigeration and so far no complaints.
  • Kevin_12
    Kevin_12 Member Posts: 31
    Raytech
    I have a raytech and it workd well but don't work on shiney objects such as sheet metal but if you put a piece of black tape on it the its ok.
  • adambuild
    adambuild Member Posts: 422
    RAYTEK MT4
    I have a Raytek MT4 and I'm very happy with it. The nicest feature I find is that it has great accuracy, reliability, and it's the smallest one in size.
