integral check
bill clinton_3
Member Posts: 111
I have a Grundfos 15-42 with integral check valve. Only trouble is the circ is cast iron and I need bronze or stainless. My supplier says grundfos doesn't make one. Does anyone know of a bronze or stailess circ with built-in check.
Thanks.
Bill
Thanks.
Bill
Grundfos makes several
bronze pumps with integrated chexk valves. The model ins designated UP 15 -XX BUC 5 (1/2" sweat) or 7 (3/4" sweat). There are several performance curves, I've attached a technical data sheet that has all of the performance curves.
I hope this helps.0 -
Try this one for the attachment
Here it is...........0 -
Thanks Rich. I forgot to mention I'm looking for a flanged pattern. The deal is I have an installation in that gets reverse flow sometimes. The pump is flanged: would like to replace with same so I don't have to repipe. Any ideas?
Bill0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
