News from Bell & Gossett
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
Morton Grove, IL.October 24, 2003 - Bell & Gossett has published an informative new bulletin that provides contractors, wholesalers, and engineers with a variety of useful data on the new three-in-one Triple Duty® Valve. The four-color, one-page bulletin (B-835) explains the features and benefits of the versatile new product and facilitates the selection and installation process.
The bulletin explains how the Calibrated Balance valve, the Non-Slam valve, and the Shut-Off valve are incorporated into one unit to minimize installation time and material costs. The bulletin also provides detailed instructions, operating data, and a diagram showing proper installation.
With a straight pattern flange design, the Triple-Duty Valve is designed to perform functions on the discharge side of hydronic pump systems. The valve acts as a non-slam check valve for zone pumping, parallel and standby pumping, and condenser water applications.
About Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.
