Riello burner sputter
Frank_3
Member Posts: 112
I could swear that this Riello F3 used to shut down to a solid stop. Now, when I listen to it at the end of a cycle I can hear the burner run on and sputter for a couple of seconds after the power is shut off.
Is this normal or is there something that should be looked at?
no its not
there is a problem you should call for service on monday and have it looked at...David0 -
Can you give me a hint as to what the service guy should be looking for? Or how can I describe the problem better so they bring whatever parts they need?
pump
sounds like it is the pump cut off and your getting residual oil drip on shut down i'm not sure if there is a delay valve which could also be the culprit if he services riello he should have everything you need good luckR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Could be a lot of things....
but i cant see it and i cant hear it so most would be a guess, it could be a bad air situation or pump or bad nozzle formming a coke ring. your best bet is to get a licenced heat pro in there and check it out the right way, fixed and tested, when was the last time it was cleaned?it should be done each year for reliability, good luck... David0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
