Kickspace heater
Robert O'Connor_3
Member Posts: 272
I have a loop hot water system. The system is feed with 3/4 pipe 2/3 of loop, when it gets to the ksh in the kit it drops to 1/2 to feed the heater and the rest of the system. Also on the last bbr it is feed with 1/2 and the return line is 3/4. My q is it ok to loop right thru the ksh and reduce the rest of the loop to 1/2 or should the heating con have used a monoflow t and keep the hole loop 3/4? And on the last rad in the loop it is feed with 1/2 and the return to the boiler is 3/4 is this ok? my e-m ad is joseph_damore at avid.com Thanks
He should have run full 3/4" to all the baseboard heat or the flow will be restricted to the whole zone.He could use either a monoflow tee or make the kitchen a seperate zone all together0 -
it sounds like a reverse return loop which if piped right works but too hard to understand you with all the abbreviations0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
