Choosing a 2 stage thermostat...help please!!
hot_rod
Member Posts: 26,594
tekmar 512. It is two stage and designed for radiant with a floor sensor option.
hot rod
hot rod
I am in the process of heating a bathroom with radiant (sandwiched between the subfloor and tile backer board). The radiant is not quite enough to heat the bathroom alone as there is a whirlpool in the corner taking up a significant portion of the floor. I needed to install a 4' section of baseboard as a supplemental heat source. I wish to control this bathroom with a 2 stage thermostat with a fairly tight differential (2 degrees max.). There is no A/C to control.
I didn't realize it would be so difficult to find a 2 stage thermostat to suit my needs. All that I have found so far are heat-cool thermostats (and even those choices are extremely slim). I want 2 stage heat only. Is that asking too much? Do any of you talented folks know of a good choice? I don't want to hang two thermostats side by side, but I will if necessary. If my only choice is a heat-cool thermostat, which is the simplest, most reliable, best choice, etc.. Robertshaw, Honeywell, ??? I had visions of calling my supplier and having them pull one right off there shelves!! Ha Ha!!
Any help would be appreciated.
Thanks,
Bob Murray
Yankee Plumbing + Heating0 -
I'm surprised by your trouble
there are lots of two stage heat stats out there, from plain to fancy. Honeywell T841, t874, t8411 and Chronotherms. White Rodgers 1F-57, 1F-79, 1f-89 and more. PSG TDMS24. and Tekmars 511/512. Hope This helps....must do have cooling too, but many are still cheap.
Boilerpro0 -
2 stage heat only
I would also like to know what you decide to use. Maybe Bill can tell us a honeywell model but the T841, T874, and T8411 are all heat & cool stats. I know Johnson makes a T25 model but it is not digital and not really attractive.
I'm not familar with the tekmar line.
Brent0 -
Thanks guys
The tekmar 512 is EXACTLY what i'm looking for. I have a 2 y.o. tekmar catalog and these aren't in it. Time to update.
So much for depending on your supplier as well ( I actually learned this a long time ago).
You guys are invaluable.
Thanks again,
Bob0
