first drop header
Can you change it to a JPG file, Clammy?
Noel
  • clammy
    clammy Member Posts: 3,227
    first deop header
    here it is my first drop header it was much easier then usual it came together like butter alot easier if your only one guy doing it, also no surging what so ever but i also skimmed her and flushed out those returns. the old boiler was a oil mae west the returns and the bottom section where just packed with rust and mud she had not been cleaned for what looked liked years had 1750 rpm beckett oil burn she was the original boiler for the house whichnwas built in the early to mid 40 .hope you enjoy thanks
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Changed it for ya , Clammy
    And that is beautiful pipework . Very well done .
  • clammy
    thanks ron
    thanks ron new at computers had a hard time posting that picture have to work on my computer skills
    NJ Master HVAC Lic.
    Mahwah, NJ
  • jeff_13
    jeff_13 Member Posts: 12
    ron nice job but i only see one pressuretrol there is the other one hiding
  • Jeff , this was Clammy's install
    You know it was one of mine if you see some copper on the returns . And we also use only one pressuretrol , unless its a commercial building .
  • No problem clammy
    when you have the pic right there on your computer you can go to "Save As " and you can save it as a jpg file , which everyone can see on the website .
  • Mad Dog
    Mad Dog Member Posts: 2,595
    Excellent freakin job clammy....................................
    Boy, we really did start a drop header revolution...everyone wants to do 'em now...keep going guys...steam is alive and well and gaining ground. Mad Dog
    Steamhead Member Posts: 17,886
    Clammy, I'm proud of you
    What a nice job. Is that a Columbia CEG-series boiler?
    Consulting
  • clammy
    thanks to every body
    thanks for the compliment,i did this one for a friend so it was a t&m job it's the first drop header but most certainly not the last alot easier to get your riser together off the boiler and world of difference by having a little distance to existing main .i get alot of bs from other mech for the way i do not only my steam job and hot water boiler but i feel that the end results are jutisifed i never have surging or priming on my sight glass .today i went back and insulated all the near boiler piping re skimmed and changed the rad vents there's nothing like dry steam and knowing that you have done your best and that your work shows that you take pride in what you do and that your not just some guy tossing stuff in as you cruse on by and being that way means you always go back and service the units you put in and stand by your craftmanship i want to thank all the regulars for posting there masterpieces for all to see and learn from it's hard to find mech who really take pride in there work and not brag rigths the true test is do you service what you install or leave the scence that the real difference and steamhead it a utica i believe model pgc 150 thanks again to all for your vast knoweledge
    NJ Master HVAC Lic.
    Mahwah, NJ
    Utica and Columbia
    are really the same boiler. I like the side tappings that you can use for skimming and flushing- if you install tees in them rather than elbows.
    Consulting
  • Gary F._2
    Gary F._2 Member Posts: 1
    Beautiful job! Just like you said it's great to see artisans like yourself who take such pride in their work and who have such a passion for what they do.I have not installed a steam boiler in many years now, but i thought that you were not supposed to use maleable fittings on steam work. They look like maleable fittings to me in the photo but i could be wrong. The eyes aren't what they used to be.
    Gary
  • clammy
    your eyes are correct
    your eyes don't lie i usally do and always though that cast was the correct way but after you see so many posted in malable i couldn't resist plus i didn't want to have to drive to 2 or 3 supply houses to get every thing nobdy around here northern nj carries all the cast stuff you need you always end up wasting 1/2 day locating everything and around here it's far and few that you see steel pipe everyone does them in copper with no insulation so this time i chose the lesser of two evil plus 21/2 fittings in ci are a little hard to come by kinda mutant size but as for pressure malable is 150 psi rated thanks again next one will be all cast
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Don't worry about the malleable Clammy
    Other than aesthetics , and maybe breaking an ell apart on the header if you had to , malleable works just as well as cast iron . I have trouble finding 3 inch fittings , cast or malleable , but I'd rather use the malleable - the wrench don't slip off the fittings like it does with cast .
    And I like the look of malleable , just my opinion .
