Help!!!
Bill Robertson
Member Posts: 1
Hi
I am in the design process for a remodel on my home. One major component of the project is replacing our forced air heat system with a Boiler. In the kitchen, entry and laundry rooms i only have 3/4" to work with (subfloor to top of hardwood floors). Do I have room to run tubes and gypcrete?? I'm going to use hydronic registers and towl bars in the rest of the house.
thanks
br
thanks
br
nope
gypcrete min. thickness is 1-1/2 inches. You could staple-up or use plates under the subfloor but may need supplemental heat. Still more comfortable with a warm floor even if it won't handle all the load.0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
