Series 100 bronze body Q
Einsiedler
Einsiedler Member Posts: 61
usually supplied when (a) system is using potable water.
or (b) the supplier ran out of IB pumps & coughed up a Bronze one in leui of.
I'd be more concerned if the situation was vice-versa.
EIN
  • Alan_2
    Alan_2 Member Posts: 28
    Is there a reason why a bronze body Series 100 circulator would be used in a series loop of a hotwater baseboard system ?
    The zone is strictly for heating only.
    The other zone, another series loop, is run by a red Series 100.
    With the bronze body circulator appearing to be a newer vintage, my guess is for some reason a bronze body was recommended as a replacement at some point ?
    Thanks for any clues.
    Also, are the pump bodies of the iron and bronze series 100 circulators interchangeable ?
    Thanks again
    Alan
  • Alan_2
    thank-you.
    no potable water involved.
    already have the motor mounts and the bearing assembly (189034) should be in tomorrow.
