New setback question
JohnNY
Member Posts: 3,341
During numerous I=B=R classes and Burnham training seminars with Mr. Jim Roche it was fully ingrained into this concrete skull of mine that setback on a residential steam system should not exceed + or - 4 degrees.
Does this way of thinking still hold true?
I dissuade my customers from exceeding those limits as a means of energy conservation. If it's a comfort issue, I tell them to do what ever makes them happy.
Comments?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=290&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Comments?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
Unless you go with
the intelligent thermostat designed for steam, they cause callbacks for overshooting, and for cold pipe condensate noises.
The clue is that they occur at the same time each weekday.
Bill Wolfe's got a good thermostat, but they will aggrevate problems that haven't been solved yet. In themselves, they are a good thing. On a good system, your 4-5° work for me. No harm would be done by more, but calls would go up with questions about the noises.
It can work.
Noel0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
