Loosing water - steam boiler
Klaus O'Neal
Member Posts: 3
I have a one pipe system with a Burnham 7 series boiler, which has been working fine. Since I have started up the heat, I almost need to add water daily to the boiler. In the years before, I only had to do this every 2 weeks.
I have checked for steam leaks - nothing, checked if the boiler was leaking - nothing. I had the boiler serviced at the beginning of the heating season and everything was fine. I am kind of dumbfounded of where the water could be going. I am not a heating expert, but this much I know, the water has to be vanishing somewhere.
I also noticed the boiler is short cycling, basically not reaching it's thermostat heat setting.
Any help will be greatly appreciated.
do you have underground
buried return pipes anywhere?0 -
Have you checked all the vents. Leakage there too can cause water lost.Sometimes they do not close due to dirt. Also you just might have a hole in the boiler(if it is an older one).That hole can send steam right up the chimney.0 -
No buried pipes
No buried pipes, pipes are all wrapped in asbestos. The house is about 200 years old, so the pipes might not be level at certain areas. I had banging pipes years ago but was able to fix that with some shims.
Any other ideas??0 -
bought boiler in '95
Let's say I would have a hole in the boiler, how could I find out??
Would there be enough white smoke (steam) showing when it exits the chimney??
Can that be fixed? a hole in the boiler.
Try filling the boiler as far as the header only. Do not go past that(if you water log the system you'll have given your self a new problem) anyways...fill the boiler to the header only...if it has a hole....you'll see it then.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
