Where to buy air vents for steam convectors
Steamhead
Steamhead Member Posts: 18,217
I'd leave it.... unless it's the only convector in a house full of cast-iron radiators.
If your convector uses a vent with the threaded shank on the bottom instead of the side, the Hoffman #41/43 or any of the bottom-shank Gorton vents, properly sized, should work OK. If it uses the standard radiator-type vent, any good vent will work OK if it's properly sized.
Maybe the best thing to do would be to take your old vent to a supply house to match it with the proper new one.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
  • Kevin Esler_3
    Kevin Esler_3 Member Posts: 2
    The air vent on one of my in-wall steam convectors appears to be leaking steam. Where can I buy a replacement ? I'm in the greater Boston area.
  • chuck_6
    chuck_6 Member Posts: 107
    I would get rid of the convector and have a recessed radiator put in. The convector doesn't heat too well. Just have a pro do it. It will cost more, but you'll have heat. Have them use Gorton air vents. Forget about Hoffmans.
  • Kevin Esler_3
    Recessed radiators vs. convectors
    Hmm, I thought the convectors were getting the job done okay, but I'm a layman.
    Are recessed radiators known to do a better job ? Will they fit in the same spaces currently occupied by those convectors ? Who makes the recessed radiators ?
    Thanks for the tip.
