Radiant and electric water heaters
smoore
smoore Member Posts: 28
  • smoore
    How well does an electric water heater work with radiant and how do you size this
  • Al Letellier
    Al Letellier Member Posts: 781
    electric heater with radiant
    It can work well if installed properly, but is generally used for small heating loads where a boiler would be too large. You need to match the input rating in BTUs of the heater to the heating load.
    Just remember two things: it's a water heater not designed for use as a boiler;check local codes to make sure you can do it with an electric heater
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    there are approx...
    3.4129 btu to a watt...therefore in a regular 4500 watt element expect about 15,300 btu...kpc
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    also make sure you can afford to run it.
    Electric in our area is between 4-5 times more $$$$$ per btu, than oil.
