ERGOMAX INDIRECT
Joe_13
Member Posts: 201
and your boiler's got enough BTU's, you should never run out of hot water. I think taking the tankless coil and putting in an insulated tank is a great idea. No sulfer odor, no bacteria growth. I hear the Ergomax's are pricey and most models sized for comercial use. I don't understand why the smallest model uses 1 1/4" Domestic water and 1" Boiler connections. You might also want to check out Dunkirk Artesian and TFI-Everhot.
Ergomax
Has anyone used a Ergomax indirect water heater ?.My heating contractor friend is raving about them. Any opinions on them ? www.ERGOMAX.com Rich....
- 86.6K THE MAIN WALL
- 54 Biomass
- 97 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 930 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
