Is this a useful tool?
DanHolohan
Member, Moderator, Administrator Posts: 16,610
that works it either direction. What do you think? I'm thinking about adding it to Books & More. Seems like it's better than trying to read upside down in those tight spaces.
Retired and loving it.
yes
What would be even better is a ruler that reads in both directions in tenths of an inch. Ron Jr was looking for one a while back and I don't know if he found it. Maybe you could take some time away from the bird feeder and look into it ;-) I know I'd buy a few.0 -
We may be able to do that.
I'm checking with our supplier. Thanks.Retired and loving it.0 -
One more question:
How long should it be? 21 feet?Retired and loving it.0 -
length
I use 30' tape for most of my work, not so much for the length but for how far it can be extended un-supported. A shorter rule with a wide blade would be fine, and the numbers could be larger. As long as we're building the ultimate rule, how about a magnetic holder? I have one that I bought from Duluth trading a few years ago. The belt clip has a steel base with a round socket, the round magnet is fastened to the rule - you just pull the rule off you belt. The added feature is you can stick the rule to any metal surface when needed. Duluth no longer carries this item, they told me it was discontinued by the MFG. It's too bad because every time someone uses by set up they want to buy one.0 -
Thanks, Tom.
I'm on it!Retired and loving it.0 -
Perfect tape measure
Yep , one you can read from either direction , and in 10ths of and inch would be great . I use a 30 ft. tape which seems to be a good size for measuring just about anything heating related , the longer length comes in handy measuring walls for baseboard heat .0 -
how about clear??
How about Clear ??
then you could read it from both sides!!
Murph'
(25'min)0 -
A realy cool tape
We have a digital tape at work thats cool for heat loss calculations. You just hold it to the wall and it bounces some sort of wave to the other wall. This seams to help you look better as you stumble through very expensive homes and try not to break anything. It's not perfect all the time but poeple seem to like it. That tapes cool too.0 -
how about the lufkin
6 ft ''plumbers folding ruler''..one side is inches, the other is the 45 degree hypotenuse reading...the 1.414.....i love mine and am thinking of giving them out for christmas presents this year.0 -
How-bout some\"golden rules\" on the back
Call it the golden rule?0 -
oh, good idea paul..
or like the ADA rules that have writing on them, for example at 34'' they say lav sink...it could have steam heights marked...like 24'' header heights or a or b dimension stuff.....0 -
Tape measures
I only buy tapes that include a metric scale as well.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
