Tempering Tank
PB_2
PB_2 Member Posts: 4
I am considering having a 50 gal electric hot water heater installed to use as a tempering tank. My system is short cycling because it is oversized. Anyody have any experience with this. I will also be installing a Termovar Thermic valve per Boilerpro's suggestion to deal with a condensation issue I had posted previously on the wall.
System is Gravity Hot Water conversion equipped as follows - Buderus nat.gas G224-45 with a Tekmar 260 outdoor reset. Currently I am looking at piping options from Dan's "How Come" and "Radiant Hydronics" books.
Thanks,
Patrick
