Mystery Pipe
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
Scott:
The whole floor is coming out because of damage done by the leaking water service which is in the slab as well. The manifold in the picture serves one of two zones.
The other manifold is staying and seems to have held up for the last 50 years; I'm surprised that the iron pipe has lasted so long; must have something to do with the coating.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Green radiant tubing
It's the first time I've ever seen this material; I think it's steel pipe with some kind of a green coating. The house looks to have been built in the 50's. It's not Bundy Weld.
In the slab
and uncovered, it has a rust coating. As you can see, it's pretty small, like 3/8" od.
ouch
I hope for your sake your removing this stuff and not trying to repair it. That looks like a problem just waiting to happen. Good luck Alan.
Scott
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
