possibly overfired??
jmacina
Member Posts: 6
i would agree with al but you may be able to a 85 maybe a 75 and may have to make a air adjustment so it will run clean.hope this will help
oversized/overfired boiler
I have an old Weil-Mclain model 366 oil fired steam boiler. It puts out 109,000BTU/hr gross-340sq.ft. steam net(81,000). But when I count up the 5 radiators in this small ranch/bungalow they put out only 140sq.ft.! Does this mean that I am almost 60% overfired? Do I have to reduce the GPH of the nozzle? By how much can I reduce it and still make steam without playing with 5 or 6 different nozzles in and out?0 -
overfired???
You didn't mention if the boiler is making hot water as well. The 366 is as small as they get for a steam boiler of that vintage. I would be careful about downsizing the nozzle much if at all. Unless the boiler is short-cylcing, it will be most efficient at or near it's desigh firing rate. Remember, there is a difference between combustion efficiency and thermal efficiency. If it's firing 1 GPM and not making hot water too, you may get away with a .85 but I wouldn't go any lower than that.
overfired???
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
