Steam tee
Steamhead
Member Posts: 18,213
it was wrong then and it's wrong now. Unless you're describing a "double elbow" rather than a regular tee- but if it looks like a regular tee, you should remove it and use two risers from the header.
Remember that a new boiler will make steam a lot faster than that old snowman, and this will aggravate any piping problems.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
I am about to ....
do a stem boiler replacement job in a home. The old boiler is a old "snowman" coal fired that was converted to oil ,then gas. I will replce it w/ a Smith GB200 series gas boiler. On the old boiler the supply comes out of the boiler and then enters a tee that is bullheaded...it has always been that way...for a hundred years ...and never a problem. How can this be? CAN I leave it that way or should I break into the main and replace it w/ 2 90's. I would like to save myself the work but....kpc0 -
As usual steamhead is correct....................I'd say that
maybe only 3-4% of steam boilers we do have salvageable headers. Especially with the low water content- fast steaming new boilers, a nice big fat header is called for. On smaller steam boilers I will either use a 2 1/2" header using both tappings OR a 3" header using one tapping. Bigger boilers always get a 3" header. Mad Dog
Speaking from experience.....
I'm going with the boys on this one. Your changing from a perkolator to a cappicino machine, and the speed at which the steam is being produced is FAR faster.That bullhead will bite you in the butt. Make a smooth and equal transition to both feeds and you'll be much better off. Chris0 -
Great anaolgy Chris ...you a funny man
mad dog
OK...
that is what I thought the answer would be...I have never heard of the double elbow before...I'll check but probably a tee. I'l get some pictures to prove I did the right thing. kpc0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
