Over fired boiler
I have a HB Smith GV-400 boiler that seems to make very wet steam, it will run for a short while , not even get to pressure, and it runs out of water and shuts off, then shortly the water returns and the boiler relights. The water looks very clean, I know the vents are not enough ( they are on order}. I have also raised the water level to an inch above the normal water line posted on the boiler. I am thinking that the boiler is overfired and boiling the water out too rapidly, also I don't know how to physically change the firing of the boiler. The previous owner was running 7 psi, I would like to get to around 2psi. If anyone has any ideas I would appreciate them.
Thanks, Phillip
    Steamhead Member Posts: 18,211
    This is a job for a pro
    Maybe the boiler is overfired, but maybe it isn't. Or it could be a combination of several factors. Regardless, the best thing to do is go to the Find a Contractor page of this site to locate a pro near you.
    If you're in or near Baltimore, e-mail me!
    Consulting
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    sounds more like...
    the near boiler piping is wrong...raising the water level won't help, just makes it worse. It's stopping because its going off on Low Water cutoff... I doubt its over fired and most manufactures won't let you change the firing rate w/o voiding the warranty....Should get a steam educated contractor out to look at it, ASAP. Where are you?
  • Mike F
    Mike F Member Posts: 23
    boiler definitely not over fired. when water is converted to steam it occupies 1700 times the space the water did. you would have to close all the windows and doors in the house and fill the entire house with steam to get the boiler to shut off on low water from water converting to steam. the problem is in the piping. you should call a few pro's and get opinions on how to correct situation.
  • Phillip Biston
    Phillip Biston Member Posts: 42
    Thanks for all of the replies, I was just hoping it was somthing other than near boiler piping. There are not any knowledgeable steam contractors in Kirksville Missouri...or in Missouri possibly. I own a 4 story brick apartment building built in 1923 (can be seen at kirksvilleapartments.com).The previous owner said the contractor that installed the boiler told him that it was to run on 7psi , and the boiler shutting off at low water cutoff was normal. I dont have the manual for a HB Smith G-400 to check the near boiler piping, if anyone knows where to find that information, I would appreciate it.
    Thanks again,
    Phillip
  • Mike F
    dan's book the lost art of steam heating
  • steve_6
    steve_6 Member Posts: 243
