Solar Collector Hookup
Paul Pollets
Paul Pollets Member Posts: 3,671
I forgot...Wirsbo Multicor or PEX-Al-PEX may be a good choice
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • CN
    CN Member Posts: 2
    I am considering installing A panel-type solar collector using Pex in place of Copper piping. I have never been involved in an installation using Pex "Wirsbo" to hook up the collectors to the Draindown system.
    Has anyone had any experience with using pex for this application....any advice would be appreciated..
  • Paul Pollets
    solar temps
    in certain collectors will exceed 200 deg. F. That is not the best temperature for Pex. I'd recommend and use type L copper.
    hot_rod Member Posts: 26,638
    Better stick with
    copper! This is what happens to pex when the pump goes out on a sunny day. I can't imagine PAP would fare much better.
    Temperatures can reach 350F or better in a stagnant system.
    Make sure you have working pressure relief valves also.
    hot rod
