Searching for a Photo
Jed_2
Member Posts: 781
I am searching for a Photograph of an installed Parallel
Secondary sub-system(wih crossovers) for a VSIM Multi-Temp
Primary/Secondary (proportional secondary mixing)residential system. I have all of Siggy's
schematics, and Dan's as well. But, my Customer would like to see a Picture of some of the great artwork. I believe it there have been some great pics in the past,but I can't download everything.
Would one of you be so kind, who has done one of these, to post a picture or two?
Thanks,
Jed
Thanks,
Jed
The trick is passing itoff as your own..........................
"....yeah, "we" do them all the time...I just don't have any pictures...yeah...I should get one of them digital cameras......" Wish I had one for ya pal, but some wallie will come thru.. Mad Dog
An excellent article
was at Siggys www.hydronicpros technical column last month, "Proportional Reset an under-utilized control strategy"
Plenty of good print and pictures. You might contact him for an archive version.
Check Siggys site for additional technical corner topics. A great "Home Run" one is currently posted.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
I trust YOU
are not implying that my intention is to"pass it off as your own". If you believe that, then, so be it. I'm just trying to provide an example of a real production of the
system. I don't do installs, but my cutomers do, and that's where the credit is applied, pal.
Jed0 -
Tahnks Hot Rod
I saw that, and the "home run" article as well. I'll check it out. But, I thought there were some posted pics
here in the past.
Jed0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
