posting pictures
go about posting your handi work on here? kpc
  • ScottMP
    ScottMP Member Posts: 5,882
    Kevin
    Its preety easy once you get used to it.
    Save your pictures in a file on your computer. I use "my documents" and make a file called " pictures ".
    Then, when you post, look down to Attachments. Clic on that and you'll see
  • ScottMP
    Kevin
    Its pretty easy once you get used to it.
    Then, when you post, look down to Attachments. Clic on that and you'll see Browse. When clic browse you'll see a little window that will allow you to go to My Documents and find the photo you want. Clic on it and then clic Add ( next to browse ). It will put the picture in the small window that says attachment. Then clic O.K. and your back to the post. You can check off the picture and it will show it with your post.
    Look forward to seeing some good work :)
    Scott
