Hot water baseboard loop taken off one pipe steam boiler.
gehring
Member Posts: 65
I have a Burnham five (5) section one pipe steam boiler with tankless. I want to add one loop of hot water baseboard heat off this boiler to service one room. I have already determined I have enough excess BTU capacity to do this. My question is which exit/inlet ports in the boiler should I tap into and on which end (out or return)should the circulator pump be located. The boiler is in the basement and the subject room is on the first floor, about 30 feet away.
Thank you.
Thank you.
Try this link
Burnham
has tappings for an indirect hot water heater, if you can remove them, use these, otherwise as along as there from opposite ends and below the water line you should be good to go. Check out this link also, i'm sure it will help.
http://www.heatinghelp.com/heating_howcome6.cfm
Ant
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
