Grease for shut off valve
mack
mack Member Posts: 1
I have a recirculating hot water heating system with ten radiators in five zones. The drain side of each zone has a shut off valve. The valves are of an old style.Basically a tapered cylinder of brass runs thru from one side of the valve out the other, perpendicular to the flow of water.There is a simple key on one end , and on the back a threaded portion with a nut and washer. As the nut is tightened this draws the taper into its female counterpart hopefully effecting a seal.There is an oblong hole in the cylinder for water flow or shut off with a quarter turn of the key. These two parts of course do not have a perfect seal with expansion, contraction and turning, and a thick paste or putty like grease is used to keep the water in its place. I've seen a gold colored graphite looking paste and a black [ petroleum based ? ] putty used but can't find anyone who knows what it is .I've tried 'plumbers grease' from the hardware store but this is too thin and I'm still getting leaks. Help!
