Snow Melt Drainage
[Deleted User]
When designing a snow melt system, should drainage for the melted snow be taken care of, or do you just let it run off into the street?
Snowmelt drain
We put a trnch drain at the bottom of the drive and ran a 3" PVC line to a 50 gal drum with holes punched in it. Works fine. Be sure to run your heat loop around the trench drain to keep it from freezing up.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
