Thermostatic Mixing valves
Wayco Wayne
Member Posts: 615
use for small radiant floor jobs as far as mixing valves. What brands do you buy and what temp range do you use? WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
mixing valves
We use either Taco or Sparco mixing valves with equal results, all good. I try to use a valve where my desired mixed temp falls in the middle third of the valves range. I find they work best in that range. Too close to the lower or highest setting can cause the valve to "wander"....
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
