Single pipe parrallel to single pip counter flow
Ed_9
Member Posts: 2
Was wondering if I can do this. I want to finish my basement and the return side sits lower than the supply side and takes up some much needed headroom. Just curious before I call someone in. Would it be possible to just cap the end of the main run and vent it (of course make sure it's pitched back properly)?
If you increase it's size you can
otherwise there isn't room for the condensate.
Noel0 -
There's more to it than that
You would need to install a new main that is one pipe size larger. The existing main was not sized to allow condensate to flow back against the steam.
A better solution might be a "rise and drip" where the level of the main is raised, and the low point gets a new "drip" line to drain any condensate that might accumulate there.
This is a job for a pro. Go to the "find a Contractor" page of this site to locate one near you.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
