needle valve
Tony Conner
Member Posts: 549
The only applications where I've seen needle valves used, are ones in which there is a need for REALLY precise control of a flow. They're FAR more precise than globe valves. It's like the difference between a tape measure and a machinists micrometer or caliper. I'm having trouble imagining a heating application where this precision would be required, and if nothing else, I think the pressure drops across them will be brutal.
needle valve
I have a blue print where the architect is specing needle valves at each branch off the riser (for baseboard)0 -
Balancers?
He probably did that so the flow to each baseboard could be fine-tuned.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.5K THE MAIN WALL
- 53 Biomass
- 95 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
