What piping is this????
Dave_13
Member Posts: 110
I've read "Primary/Secondary pumping made easy" and understand a few of the different piping configurations, but what's the technical name for the one in the drawing? What are pluses and minuses of piping this way? I know there would have to be a mixing valve on the radiant and I guess each loop pump would have to be sized for the loop, boiler and all the piping to and from. Would there be a problem with 1 loop running and affecting others? All loops would be supplied the same temp water I assume? Thanks for any responses- just trying to understand!!!
That's a basic multizone system.
The radiant pump will go on the mixing valve's outlet port, not either inlet port. Flocheks on the zones keep the off zones from having flow.
Noel0 -
So....
What your saying about the Mixing valve is that you would be pulling water through both inlets by having the pump on the outlet of the mixing valve??0 -
exactly
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
