massachusett apprentice looking fo help
i am a 2nd yr apprentice i do a lot of jobbing and no heats but i was wondering if anyone had a good book or link for venting and waste ie wet vent ,circuit venting or battery vent its something i dont do alot of and id like to be a complete plumbing and heating contractor when i ask the journeyman i work with he only explains it quickly id like to learn some on my own
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    National Plumbing Code
    Is a REALLY good book.
    It's reasonably easy to understand in most sections and while not "the" code in most states, I believe that all other plumbing codes (generally MUCH more detail- and material-oriented) must comply.
    Since it is based more on theory than actual application even a years-old used copy will be nearly (if not completely) identical to the latest printing.
    It acknowledges its own age, essentially saying that while materials and details may change, the underlying hydraulic principles are the TRUE laws that govern. The later portions of the book are DEEP hydraulic theory that makes for good study when sitting on its' primary reason for being.
  • paul lessard_2
    paul lessard_2 Member Posts: 192
    reason for being.....good one mike
  • Geo_2
    Geo_2 Member Posts: 76
    Here is the massachusetts code book online http://www.state.ma.us/reg/boards/pl/rule_reg.htm
