Advice Needed: Direct Vent or not? Indirect vs Direct WH?
Tom Asaro
Member Posts: 18
I am in the process of adding a 2nd floor to my ranch home. I built a mech room on the 2nd floor so I could change the entire house from forced hot air (gas) to hot water baseboard (gas). I also want to change my electric HW heater to something more efficient. I am having a hard time deciding what type of boiler to go with. I was planning to get a high efficient direct vent (Peerless PI-140), but was told that it would make too much noise on the 2nd floor. I was also planning on getting an indirect-fired water heater, but was told that they are not efficient because the boiler has to run year round. If it makes more sense, I can always install a conventional boiler and WH. Any help is greatly appreciated!
Got that backwards.
An indirect water heater running with an 86% boiler is NOT less efficient than a 70% gas water heater, or an electric water heater running from a 30% coal generating plant miles away from the house.
I vote boiler with indirect.
Noel0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 771 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
