Unico Hot-Water coil
Jamie_6
Member Posts: 710
I am looking to install a hot-water coil on the tail end of a Unico 2430 Air handler. I would need to use a 30% glycol mix witch would give me about 36,000 Btus. The problem I am having is, I do not know how to size my riser or pump.
I do know that I will have a resistance of 16.1 through the coil, 8 GPM, 80 feet one way to the coil, and a flat plate exchanger. Any comments will be greatly appreciated!
Jamie
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Jamie
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
