Broomell Re-Pipe - DF
Dan Foley
Member Posts: 1,268
Here are the "before" photos of a Broomell system we re-piped this week in Takoma Park, MD. The complaints were high fuel bills, water hammer, and no heat at the radiators. Can you see why? The steam mains are directly connected to the dry returns. There was not a main vent anywhere on this system.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=262&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
After
I went back to clean and skim today. It was humming along at about 8 oz. of pressure and all the radiators were hot. The system was whisper quiet with no banging or hammering. -DF
Dan, that's beautiful
I can't see the vents clearly- Gortons?
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0 -
Vents
Hi Frank. Thanks for the compliment on our work. I used four #75 main vents on this one (two per return main). I wanted to use the Gorton's on this job. I attempted to purchase them through my local supplier. He contacted Gorton and was told he needed to buy a minimum order of ten vents. I only needed two so I used the Hoffmans instead. -DF
Ahh
I keep forgetting they don't paint the Hoffmans green anymore.
Contact Gorton directly- try their gear and if you like it, your supplier can order ten at a time cause you'll use them! Have them send you a #2 to test out. You'll love it.
www.gorton-valves.com
Consulting0 -
Hey, Dan
Sweet!
Noel0 -
Nice Piping!
Sweet! How do you insulate the mains?
