Manifold Boxes
hot_rod
Member Posts: 26,604
at Able in Chicago 773-988-7649. He is a dealer for this Oventrop brand. Probably a UPS day, or two, away.
I sometimes use these Able Acess PVC panels, made in Cleveland, Ohio. A variety of sizes, and very inexpensive. Most plumbing supply and box stores have them on the shelf.
hot rod
hot rod
Manifold boxes
Does any know who manufactures manifold boxes ? Which is the best and were can I purchase them in Northeast Ohio.0 -
Indoor or outdoor?
Lawn sprinkler supply shops have a wide selection of plastic yard boxes for use in the ground.
Many of the manifold manufacture offer boxes for use in the wall inside the home. Oventrop is one I know of. Check also with the Radiant Companies Wirsbo, Watts Radiant, Rehau, RTI, etc, etc.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Manifold Boxes
Indoor, for Wirsbo manifolds in stud walls.0 -
Thank You very much, Sounds like a winner.0
