Chiney liner
Al Letellier
Member Posts: 781
Many variables here, Wayne. General speaking, a tiled lined chimney in good condition will be OK for the Buderus. If it's in good condition and in conditioned space. A outdoor chimney should be lined as the flue gasses will deteriorate the liner in a hurry.
Team up with a good mason or sweep and inspect EVERY chimney you tie into.
The 300 degrees is at the breech, and is much lower in the chimney itself, so be careful.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=248&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
I'm pricing
a new boiler for a customer. I'm trying to sell him on a Buderus Oil fired. I read that the flu gases can get as low as 300 F. How do I know when I need a flu liner with oil for a masonry chimney? I do mostly gas and have little experience to draw from for oil. WW
How to get in touch with a qualified chimney sweep
Hi, Wayne. You can call the National Chimney Sweep Guild at 317 837 1500 and they will refer you to a CSIA certified sweep in your area. I just had my fireplace & heat chimneys cleaned and inspected with a camera. Talk about a learning experience! There's a lot more to chimneys than most people think, and the CSIA sweeps know what they are about. If you find a guy you can work with, keep the name in your biz card file, and then you can have an expert on call when you run into a chimney issue that you don't feel comfortable diagnosing.0
