plates on top of floor
my job where I plan to install some joist trak plates on top of a floor with 8 inches of 3/4 plywood in between each plate. There will be a hardwood floor on top so I have to go perpendicular to the direction of the hardwood boards so the flooring people have someplace to nail. I have a question though. I have 3 loops in this room, and I don't think I can get into the crawlspace. How do I install the leader tubes to the far loops and still leave a place for the flooring people to nail. Because I would be traveling parallel with their boards. I usually drill down beneath the floor and travel back to the manifold. Not sure how I'm going to make this happen yet. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
    hot_rod Member Posts: 26,607
    Are the room dimensions
    to large to let the leaders travel in the plates as heat loops? Probably be easier to draw that question :)
    Better yet show us a sketch of the room shape and dimensions, including manifold location, and joist direction.
    I have also fished PAP 30 feet or more through joist bays without getting under the space. I suppose 1/2" copper rigid with insulation could be used for this also.
    hot rod
