Heatloss Software
wingnut
wingnut Member Posts: 3
Does anyone know where I can Get a good heatloss program?
  • Alan R. Mercurio
    Alan R. Mercurio Member Posts: 588
    Wingnut, Check out the 4th Link up from the bottom on the pipe to your left.
    Your friend in the industry,
    Alan R. Mercurio
    Oil Tech Talk
    hot_rod Member Posts: 26,619
    Better yet
    go to the Books and More button and grab a copy of Siggy and Mario's software. In addition to a nice, clean easy heatloss program, including a basement calculator!
    There is an incrediable amount of hydronic design components that no serious hydronic designer/ installer should be without.
    Spend a couple hours with this software and you will be a hydronic design machine.
    hot rod
