expansion formula
bottomheater
Member Posts: 8
any one have the formula for figuring expansion tank size? It appeared once in John s.'s column, but I'm filing challenged, and now I've got to keep a run amok engineer from savaging a 2.8 million btu system and beat him to find a solution and stay within HUD limits. 'd be obliged.Tnaks
Just head to the site below. when you get there click on professional installer then click on product sizing.
Amtrol
Hope this helps.
Your friend in the industry,
Alan R. Mercurio
Oil Tech Talk0 -
expansion formula
its the math im after, not a select a tank format. its for argumentative purposes. thanks the same0 -
where is John Siegethalers math when you need it
no,Mike E.'s article did get past the thirteenth fl, where the modular boilers are @2.8 million btu, some engineer says my BIG 125 gal ASME bladder tank is not enough,didnt show his calc, doesnt know system volume( lots of 3to 3/4 pipe in walls)and I want to throw F=(y/z)x ? at him.0 -
I was told by the Bell and Gossett guys years ago
BTU x .02 divided by temp example 135,000 btu x .02=2700
then divided by 180 deg water temp = 15 gal tank0 -
I have it
Retired and loving it.0 -
I have it
kudos
bless you Dan and your incredible creation. its just a matter of phrasing it right.0
- 86.5K THE MAIN WALL
- 53 Biomass
- 96 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 928 Plumbing
- 6.1K Radiant Heating
- 384 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
