Brick wall finish
Mad Dog
Mad Dog Member Posts: 2,595
...we are leaving the chimney exposed in the kitchen..we wire wheeled all the old soot off...and i's like to seal it with something. i've seen them do this in restaurants and bars - it looks great......is it polyurethane? It just give it a little sheen and richens up the look...does anyone know what the heck im talkin about??? MAD DOG
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • ScottMP
    ScottMP Member Posts: 5,882
    Matt
    They make a product called Stone Luster, and I am sure there are other brand names. They are made just for coating brick. Most come in a gloss or satin finish and you should be able to find them at a lumber yard or masonary supply.
    Happy Saturday
    Scott
    hot_rod Member Posts: 26,592
    Plenty of options
    Check with a tile or brick suplier. I'm doing a home where they sanblasted all the basement walls, for a finish! They tried a half of dozen different sealers, on a sample piece of concrete, to get the right look. Some were glossy, some low sheen, just depends on your taste.
    I used a non toxic latex product on my concrete counter top and slate floors in my bathroom, dull finish. Looks and works great. Also odorless! Water clean up is nice. Got this at the Home Depot.
    hot rod
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Old house? Old bricks? Flue still in use?
    If so, unless that flue is lined with stainless I wouldn't seal that brick and only reluctantly then.
    Old, soft brick and mortar MUST "breathe"! Cut off its ability to relieve high moisture from the other side and the mortar crumbles and the bricks spall. I have seen this MANY times.
