Vitodens problem
Ted_5
Ted_5 Member Posts: 272
clear the fault first. Check incoming gas, see if screen or
orifice is pluged.
Ted
  • steve gates
    steve gates Member Posts: 329
    code 14
    I've got a code 14 in a 9 month old Vitodens. Just got back from a roadtrip sending my daughter to USF Tampa and it wont fire.
    I will be going back tomorrow, with tools, before the owners arrive back from their vac...
    Anyhints?
    Have propane, hear the ign cliking, the gas valve cliking open?. the cond trap is clear.
    Is tec support open on sat?
    Thanks in advance!
  • doug_10
    doug_10 Member Posts: 102
    tech
    support is open 24 hours a day.
    Michael Bleier
    Able Distributors
  • steve gates
    got it
    just a small adjustment screw that the tec was told shouldn't have to be touched.
    clockwise 1/4 turn+ on the gas valve.
