News from B&G
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,686
Morton Grove, IL. August 19, 2003 - Bell & Gossett has introduced a new Triple Duty® Valve that performs all of the functions of three valves that are normally required on the discharge side of hydronic pump systems. By incorporating three valves in one, the new valve saves significant money in material costs and minimizes installation time.
The new Triple Duty Valve includes a calibrated balance valve, a non-slam check valve and a shut-off valve. The calibrated balance valve optimizes system operating efficiency and provides precise flow with a maximum range of control (8-9 turns). The non-slam check valve assures positive shut-off free of water hammer or valve chatter as needed for zoned pumping, parallel and standby pumping, and condenser water applications. The shut-off includes a calibrated nameplate and memory button allowing the entire valve to be returned to its initial balanced position after shut-off.
Providing the lowest pressure drop of any similar valve, the Triple Duty Valve meets ASHRAE 90.1 requirements for energy efficient operation and is also compliant with the National Energy Building Code Standards.
The valve is available in a standard straight pattern flange design, and is constructed of durable materials that resist harsh operating pressures, high temperatures, and aggressive liquids, ensuring a long life.
About Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, hydronic specialties, heat exchangers, condensate handling equipment, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Retired and loving it.
