Large Radiant
Mark Eatherton1
Mark Eatherton1 Member Posts: 2,542
the most productive, comfortable employees in the county! Good job Gregg. With the MASSIVE floor they've got, they'd probably be able to go without heat for a week before they even notice that the heat is off!
ME
  • Gregg Jackson
    Gregg Jackson Member Posts: 55
    new land speed record..................
    This is a large truck body fabrication facility. There is just over 22,000 square feet of in slab radiant. We decide to run large bore pex (1.5") undergound out to each manifold. The pex was pricey but the labor savings were incredible. The nice part is that all of the distribution piping is done and back to the boiler. No piping overhead on staging or lifts. The amazing part is that we got all of the insulation, tubing and manifolds in and tested in less than 3 days (yes they were long ones. We didn't want the owner to lose his concrete guy for another two weeks so we sucked it up and got it done. The system will be fired by two Vitola VB2-63 oil boilers. Will post pics of the finished boiler room. Thanks to our Rehau / Viessmann rep and salesmen who pitched in.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    You could
    teach a class off those photo. Well done!
    Retired and loving it.
  • Andy Morgan_2
    Andy Morgan_2 Member Posts: 147
    Wow
    I am glad I wasn't the one tying all that pex!
    You got to love it when there is little to no overhead work in a building like that.
    Nice job!
    Andy Morgan
    R. Morgan Mechanical,LLC
  • John Jr
    John Jr Member Posts: 210
    Rehau Rep
    Greg who is the rep for this area? How do you like working with this tubing vs wirsbo? Nice job. I drive by every day saying that buidling would be great for radiant. They won't be sorry for doing it. I did one 70 x 80 on St Paul street the guy loves it and what makes it better the other half of the building has forced air.
    John Jr
    hot_rod Member Posts: 26,602
    Nice job
    What center spacing did you use? A mini tube system works real nice for those wide open spaces also. Generally 1/2 or 3/4 is adequate for distribution with mini tube injection.
    They will be very pleased with that system!
    hot rod
  • Floyd_2
    Floyd_2 Member Posts: 52
    Looks like ......
    5/8 tubing, on 12" C, all on F/B/B/WP.....
    What #'s did you use for the heat loss??? I am getting set to do a 10,000 SF job and figured that I could run 5/8 on 18" and have plenty of spare BTU's @ -10 outside with a 60* inside 110* water.... with what you got there you should be able to run some really low water temps.
    Looks GREAT!!!! radiant is the ONLY way to go in a building like that!!!!
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    what did...
    you use for insulation? I can't quite tell...very nice work! kpc
  • Mad Dog
    Mad Dog Member Posts: 2,595
    WoW! how many men were on the install?
    That's a lotta work period! Mad Dog
  • Arthur
    Arthur Member Posts: 216
    Large radiant
    Nice job, What sort of digital Camera you got and what resolution did you use to post them ??
    Floyd
    I think you are right that 18" will generally work in these type of shop installs. I have used 15" as a compromise. I alternate between 12" and 18" every other loop. This allows every tube to fall on a parallel grid on the mesh.
    Hard to keep a tube tied between the squares, I've found. Seems the concrete shoves it one way or another.
    This link has some data on tube spacing.
    hot rod
    http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,19951,00.html
  • Tim Doran_2
    Tim Doran_2 Member Posts: 131
    Nice work
    Nice looking job. Any concerns with flow on the Rehau manifold due to it's small bore? What is the Cv per loop? I have been using Wirsbo's new True Flow which has an inch and a half bore and is pretty competitive with the Rehau one. I also like thier new balancing tools. Great job!!!!!!!
    Chris
