My frist Buderus Boiler
Bart
Bart Member Posts: 14
The HX is for a glycol loop and boiler protection, this
board was built on site. We recessed the HX into the board
to keep piping straight,looks neat.
And I did paint everything to match the Buderus, I know,
Don't get out much.
  • David Sutton_3
    David Sutton_3 Member Posts: 160
    This was fun !!!!
    well i did my frist european boiler and i had a blast . the piping had oy go over the boiler because the foot print for the heating sys was only about 4' sq. there was no room to anything else on the left 5 feet away is the elec. panel ,on the right the walk way for the cellar no room for nothing behind it the chimney.
    this was a mixed system 3 zones of radiant in the cellings and 2 zones of high temp Baseboard. used the 2107 outdoor reset control.
    the H.O. lft this morning on vacation and will be back monday, he's in for a big surprize i think.
    all i have to do tomorrow is smoke pipe, wire it and test it. then its done. .... well what do you think?? go ahead be honest( not too honest though) i can take it. cant wait till next week to do another :)
  • Ron Huber
    Ron Huber Member Posts: 121
    Good Job
    A clean, mean, heatin machine!
    Bet your customer appretiates the difference from the old system?
  • Steve Ebels
    Steve Ebels Member Posts: 904
    Look's nice Dave
    What did you think of the boiler and tank. Any questions or problems with the control?
  • Bart
    re:buderus
    Nice Job Dave
    pre-built boards are alot of FUN also, saves time
    and money to assemble in the shop - no running...
    Had a great time designing this board, and had alittle
    more room than you.
    You will notice the tekmar - long story, but that
    buderus control is smokin! R2107
  • Bart
    re:buderus
    Nice Job Dave
    more room than you.
    buderus control is excellent R2107, would have saved
    alot of wiring, works great with these argo controls.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    ok I'll bite.............
    did you paint everything blue? How did you get it to be so neat and glossy...? Why the flat plate HX ? NIce work....Both of you! KOC
  • David Sutton_3
    Nice work Bart!!
    lookin good , hopefuly i'll have more room to build a board like those . keep up the good work you make us all look good ...David
  • Bart
    re:painting
    I did paint pumps etc. to match the Buderus blue,
    what - ? I dont get out much.
    The flat plate is for a glycol loop and boiler protection,
    that board was built on site, cut the plywood to recess EXCH
    to avoid elbows.
    I hear the room is painted and floor tiled now and pex hold
    trimmed out, will have to get back for a couple more pics.
  • What an improvement , Dave
    Jeez , the boiler and heater combo look 8 feet tall . Did you do the piping before the Buderus was in place or after ? Beautiful work in a limited space , Dave .
  • Richard D.
    Richard D. Member Posts: 32
    Don't you
    paint the walls too!!!LOL....Great looking job!!I see you have a mixing valve w/4 zone valves,what type of heat in those zones??Is it in floor down the line??I see no pex..Just nosey!! Thanks Rich
