Removing rust from copper lines.
Rob_9
Rob_9 Member Posts: 1
Does anyone know a way of removing rust from copper without replacing the whole system. The lines are not block, but working on them, I am finding rust on the inside. Steps have been taken to stop more rust from the well (high iron) but I would like to get rid of what is in the lines.
  • Terry_4
    Terry_4 Member Posts: 42
    try this link
    Check out sani-well from pro products. It really works.
    http://www.proproducts.com/products/specialty/index.htm#oxalic
    Terry
    hot_rod Member Posts: 26,604
    Cleaners are available
    make sure you select on for use with potable water.
    You are right in having to correct the problem at the well. I have a venturi system on my well which has high iron. Every pump cycle it sucks in O2, then a contact tank allows the rust to fall out. It backwashes like a softner. Works well up to a certain level.
    My last home had REAL BAD iron. There we had an Iron Curtain. It used a compressor to inject air (O2) which caused the iron to fall from solution, a large contact tank, ans a multi layer filter with auto back wash.
    Make sure you check ph also. Once you strip the copper clean it becomes very "attackable" It needs to have a patina or layer to protect the tube (and provide a bacteria base :)
    Try www.rhomarwater.com for cleaners, also.
    hot rod
