Johns Manville duct
Mark J Strawcutter
Member Posts: 625
If I understand the situation, the JM fire that affected their ability to produce pipe-wrap insulation also shut down their manufacture of round duct.
Since Unico and Spacepak both allow/require "super round" or "rigid round" for plenum, I wonder how they'll be affected by this. Especially Spacepak since it's required. Unico allows alternatives.
Mark
Mark
No insulation
This is going to become a major pain as the summer unfolds into fall and large (and not so large) construction projects are held up indefinetly. We have had a couple of projects put on hold because of this problem.
Let's hope the few other manufacturers kick into high gear and pick up the slack.
Bob D0 -
I talked with a Spacepak rep
He said they would be using square duct.
David0
