Buderus boiler
C Forrest
Member Posts: 5
Buderus boiler G224E. A replacement boiler for our existing radiant heating (slab).
Thank you for your help!
CF
CF
Buderus Boiler
I am considering replacing our 50 yr old boiler with a Buderus G224E cast iron boiler for our existing radiant heating (slab). Has anyone encountered problems with this make/model?
Thank you.0 -
Teledyne Laars JVS
I am considering replacing our 50 yr old boiler with a Teledyne Laars JVS boiler for our existing radiant heating (slab). Has anyone encountered problems with this make/model?
Thank you.0 -
can we have more...
info. please. What model Buderus? What is your application? Is there to be a total radiation replacement. a bit of radiant added or just a boiler swap out? Teledyne is an ok boiler(I had one in my last house a JVs, not one problem in 9 yrs. ) and I am putting a Buderus oil boiler(115-21) in my new house. Hope this is helpful. kpc0 -
Have no experience with
the teledyne boiler, but have installed the Buderus. Works very well. Would have no qualms recommending it. WW
I am considering replacing our 50 yr old boiler with a Teledyne Laars JVS boiler for our existing radiant heating (slab). Has anyone encountered problems with this make/model? Thank you.0 -
are you sure of...
the model #? Either way Make sure the new boiler is sized properly NOT oversized. and installed properly to not harn=m the old system or kill the new boiler. Best of luck,kpc0 -
I have never encountered a Buderas that wasn't meticulously assembled. It is a quality product. Their silicone casting on their cast iron sections really helps to reduce thermal shock. Which is something I would be really concerned about with a retro-fit. I am a buderas man through and through. And after two decades in the business I have seen em all.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
