Head loss in cast iron radiators
MDineen
MDineen Member Posts: 1
does anyone have information on how to calculate head loss on cast iron radiators?
  • Nil...
    Zip... Nada...Zero.
    Especially if you flow it at the delta T it was originally designed for, 30 to 40 degrees. Even if you double the flow rate, 3-1/3 times zero is still zero.
    Oh yeah, did I mention the valves had to be wide open and there shouldn't be any orifices in the radiator piping?
    Zero.
    ME
