2 pipe oil
I forgot about duplex bushings! We stopped two pipe long ago.
  • Don Dada
    Don Dada Member Posts: 2
    2pipe oil.
    when you pipe an oil tank for a 2 pipe burner, the supply line drops down to about 6" from the bottom, should the return line drown down nearly the same distance or can it just stay a few inches from the top?Thanks, Don
  • John@Reliable_4
    John@Reliable_4 Member Posts: 101
    It should be about.................
    3/4" of an inch above the supply line. Even better is not using one. Many reasons but the best one is most oil leaks are on return lines. Hope this helps John@Reliable
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    Separate the two lines by
    3"-4" of height if you use a duplex fitting. The suction line can and will pull any air from the return line back in if it is too close. If the are at opposite ends of teh tank it doesn't matter.
  • jose
    jose Member Posts: 17
    I usually
    Just stub the return line in the tank thru the duplex bushing about 12 into the tank.
  • David Sutton_3
    David Sutton_3 Member Posts: 160
    2-pipe oil lines
    if it is a underground tank 4" off the bottom is good and have the return line about 3" above that. The way i like to do it is to use slip couplings in the duplex fitting, useing 1/2" oil line i put the two line thru the fitting and twist them together, on about a 4' lenth there is only one to one and a hlf complete turns(like a cork screw) then i kick the return line out , on the last 2" just so it dose not dump right on the suction line.then install it in the tank. hope this helps ..David
  • Paul Mitchell
    Paul Mitchell Member Posts: 266
    lines
    gotta be down close to the same ..mini pump could lose prime if the tank is lower than the burner
  • Don Dada
    Oil lines
    The reason I ask is because on a recent install, I did use the duplex bushing, the supply line went about 5" from the bottom but I only piped the return line a few inches INTO the tank. Is this a problem? Should I return and pipe it down further closer to the supply line. If so why does it NEED to be lower. Thanks for the help guys. Oh yeah the tank is inside the basement. DD
    / Member Posts: 1
