in floor hot water heating
> I have a shop floor with plastic hot water <BR>
> heating pipes. Some of these pipes have cracked <BR>
> as the floor has settled. Is there some product <BR>
> I can put in the water to seal the leaks, such as <BR>
> Bars Leaks or Allumaseal. These products are used <BR>
> in engine radiators. <BR>
<BR>
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
<BR>
infloor heating pipe brakes
I have a shop floor with plastic hot water heating pipes. Some of these pipes have cracked as the floor has settled.
Is there some product I can put in the water to seal the leaks, such as Bars Leaks or Allumaseal. These products are used in engine radiators.0 -
Not that I know of.Geoff,
No easy way that I know of,,,
Geoff,
However, It may be possable to locate the leak(s) and repair them with a little demolition from above. I use an infared thermometer and have had good luck so far repairing broken embeded tubing.
What type of plastic tube was used?
Pipedream;-)
The floor settled?
The floor settled?
Plastic tube cracked because the floor settled?
Did you build on a sink hole?
Who's tube was it?
Mark H
The bigger question
is why the floor is moving? Until you can determine this I wouldn't spend much time trying to fix or locate sheared tubes.
It is not unusual for concrete to crack, and generally this does not damage the tube. If the slab has settled or moved this may be on going based on jobsite conditions or improper backfill and prep work under the slab.
There are sealers for pin holes and such, but ripped tube would be another issue.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
The bigger question
